WaitOnEvent Timing out
@master9991 wrote:
I am indeed sending the termination character. You check the code I posted above.
_gpibSession.TerminationCharacter = 10;
_gpibSession.TerminationCharacterEnabled = true;
No, you are not. I told you that above which you didn't bother to read apparently.
Message 11 of 15
(2,337 Views)
I sending the same parameters in VB6 and it works.
I have read what you said (given under) but that didn't solve my problem.
"One thing you should note is that TerminationCharacter is for read *only*.
You will need to add your own when writing to the instrument."
Message 12 of 15
(2,332 Views)
Today I tried running the NI-VISA DotNET4.0  example for Service Request
- I am still getting time out when it waits on the "WaitOnEvent"   [Synchronous mode]   [GPIB-USB-HS with Windows 7 64 bit]
- It never runs the Handler routine                                                     [Asynchronous mode] [GPIB-USB-HS with Windows 7 64 bit]
But when I run my VB6 code for the Service Request it runs perfectly  [Using a PCI-GPIB Card with Windows XP]
Any help is appreciated.
Message 13 of 15
(2,311 Views)
Run your VB6 code with the GPIB-USB-HS
Message 14 of 15
(2,306 Views)
Ran VB6 code for the Service Request and it runs perfectly   [GPIB-USB-HS with Windows 7 64 bit]
viStatus returns "Operation Completed Successfully"
Message 15 of 15
(2,293 Views)
