Graph 1 column out of 2d array in vb.net w/out a temp array
I'm using cwgraph to plot time vs a 2d array like so:
cwgraph.plotXvsY TimeArray, 2dArray
Is there a way to use this same call to plot a selected column out of my 2d array without having to create a temporary 1d Array?  When you have 30 channels with 1,000,000 points per channel it can be time consuming to separate the 2d into 1d arrays.
Thanx!
B
(3,878 Views)
Depending on the source of your data, Instead of having a 2d array of the form double[,], can you have an array of arrays? ie. double[][] theArray? In that fashion, you could just pass theArray[0] to be plotted. (Looking at your post again I suspect this will not work given that your DAQ data is probably coming in as [,])...
It's a shame you can't pass IEnumerable<double> into the plotting routines of the NI graphs...
(3,847 Views)
