Why is my PushButton3D switch change its background color to dark grey?
I am using Measurement Studio 8.0.1 in Visual Studio 2005 C#. The problem occurs when I change my NI Pushbutton3D enable property to false. During program runtime, the background for the NI Pushbutton image changes to dark grey. Is there any method to resolves this issue. Thank you in advance.
(4,122 Views)
  I'm going to have to check this with the developers.
You could programatically ignore presses (drop into the code that runs when you push the button and decide if you need to react to it or not).
Hope that helps
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(4,101 Views)
This was reported to R&D (# 43838DW3) for further investigation
I'll let you know more as I get notified on it.
Sacha Emery
(4,083 Views)
hi Sacha,
Thanks. Do let me know if there's any outcome from your R&D to resolve this issue.
Lavon.
(4,079 Views)
Hey Lavon,
Just to let you know that this issue has been resolved in the current version of Measurement Studio - version 8.1.1
Regards
Hannah
NIUK & Ireland
(3,846 Views)
