Graph.DefaultPlotRenderers.ReplaceAll() does not cause any changes to GUI
WPF C#
I have no idea what I am doing differenly from DefaultPlotRenderers example that came with NI Studio.  I can see in debugger that DefaultPlotRenderers object contains either nothing or my custom settings (based on option I select).  This matches how it looks in debugger in the example from NI.
Here's my code and any help would be greately appreciated.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Shapes;
using NationalInstruments.Controls;
using NationalInstruments.Controls.Primitives;
using NationalInstruments.Controls.Rendering;
namespace FireflyMmwDiagnostics
    public partial class GraphLinear : Window, INotifyPropertyChanged
        private bool m_includeMarkers = true;
        public bool IncludeMarkers
            get { return m_includeMarkers; }
            set { m_includeMarkers = value; OnPropertyChanged("IncludeMarkers"); }
        public virtual event PropertyChangedEventHandler PropertyChanged;
        public virtual void OnPropertyChanged(string name)
            PropertyChangedEventHandler handler = PropertyChanged;
            if (handler != null)
                handler(this, new PropertyChangedEventArgs(name));
private readonly PlotRendererCollection PlotRendererCollectionWithMarkers = new PlotRendererCollection(); public GraphLinear() { InitializeComponent(); DataContext = this; } public void AddData<T>(List<T[]> data) { T[,] arrayData = new T[data.Count, data[0].Length]; for (int plot = 0; plot < data.Count; plot++) { // Create plot object AddPlotToGraph(data[plot].Length, ""); // Convert list to array for (int point = 0; point < data[plot].Length; point++) arrayData[plot, point] = data[plot][point]; } // Assign data Graph.DataSource = arrayData; } private void AddPlotToGraph(int dataSize, string label) { Brush brush = Utility.RandomBrush(); ChartCollection<double, double> chartCollection = new ChartCollection<double, double>(dataSize); Plot plot = new Plot(label); LinePlotRenderer linePlotRenderer = new LinePlotRenderer() { Stroke = brush, StrokeThickness = 2}; LinePlotRenderer linePlotRenderer2 = new LinePlotRenderer() { Stroke = brush, StrokeThickness = 8 }; PlotRendererCollectionWithMarkers.Add(linePlotRenderer2); // Store away alternating plot setting plot.Renderer = linePlotRenderer; Graph.Plots.Add(plot); } private void CheckBoxIncludeMarkers_Click(object sender, RoutedEventArgs e) { if (IncludeMarkers) Graph.DefaultPlotRenderers.ReplaceAll(PlotRendererCollectionWithMarkers); else Graph.DefaultPlotRenderers.Clear(); }
     // This is a snippet from other class where I make a call to show this graph...
GraphLinear graphLinear = new GraphLinear(); graphLinear.AddData(listOfSmaData); graphLinear.Show();
(5,400 Views)
In your AddPlotToGraph method, you are explicitly assigning the Renderer of the new plot (plot.Renderer = linePlotRenderer;). A locally assigned renderer always takes precedence over the default renderer in the DefaultPlotRenderers collection.
~ Paul H
(5,390 Views)
Ah, I see... I just verified this.
So what's the best way to toggle my own custom plot settings?
Just by traversing through custom list of PlotRendererGroup based on my option?
Something like this
Graph.Plots[plotIndex].Renderer = ListOfPlotRendererGroups[plotIndex];
Thanks!
(5,384 Views)
Accepted by kirko7
If you need the plot renderer to be set, then manually updating the renderers on all plots would be the way to go.
If you leave the plot renderer unset, you could toggle between two default plot renderer collections (i.e. save both linePlotRenderer and linePlotRenderer2 into collections, and in the check box handler update with one collection or the other).
~ Paul H
(5,381 Views)
