Help with changing the scaling of a virtual channel?
Can someone please help me with this block of code that I have?  I do not understand why on the first execution it works fine with no daq Exception errors, but on the second execution I get an error.
More detailed, I am creating a virual channel in one Sub with a button click event.  That virtual channel is set to default values (MIN = -10, MAX = +10, Linear Scale with Scale and Offset at 1 and 0 respectively).
In the other Sub click event, is where I am having the difficulties.  In this Sub I am creating the custom scales and assigning values to them, setting the MIN and MAX values of the virtual channel to the same minimum and maximum values of the Custom Scale being used, and then finally assigning that new custom scale to the virtual channel to use.  The code works for the first execution.  When I change the scaling and then execute the code again for a second iteration, I get a daq Exception error.
Its appears that the MIN and MAX are getting set on the second execution but the Scaling is not being reset to a the new scale values.  Can someone verify and if so, what is wrong and needs to be changed in my code?
First Execution of the "DownLoad" button click event to assign the custom scale with its values to the virtual chanel.....works fine.
Change the Scaling, in this case from 400 to 600, and then execute the same code again with the "Download" button click event and I get the daqException Error
myTask.Control(TaskAction.Stop)
        PreScaledVals.TrimExcess() : PreScaledValsArray = PreScaledVals.ToArray
        ScaledVals.TrimExcess() : ScaledValsArray = ScaledVals.ToArray
        If chkBoxTblScale.Checked = True Then
            Try
                min = ScaledValsArray.First
                max = ScaledValsArray.Last
            Catch ex As Exception
                MessageBox.Show(ex.Message & "  Table Scale must contain at least two prescaled values and two scaled values.")
                Return
            End Try
        ElseIf chkBoxLinScale.Checked = True Then
            min = numEdtMIN.Value
            max = numEdtMAX.Value
        ElseIf chkBoxMapScale.Checked = True Then
            min = numEdtSMin.Value
            max = numEdtSMax.Value
        End If
        LinScale = New DAQmx.LinearScale("Linear Scale", scale, offset)
        RMPScale = New DAQmx.RangeMapScale("Ranged Map Scale", prescaledMin, prescaledMax, scaledMin, scaledMax)
            Try
                TblScale = New DAQmx.TableScale("Table Scale", PreScaledValsArray, ScaledValsArray)
            Catch ex As DaqException
                MessageBox.Show(ex.Message)
            End Try
        End If
        Try
            If cboBoxChannels.Text = "6" Then
                ChannelSelected = 6
            ElseIf cboBoxChannels.Text = "7" Then
                ChannelSelected = 7
            ElseIf cboBoxChannels.Text = "8" Then
                ChannelSelected = 8
            ElseIf cboBoxChannels.Text = "9" Then
                ChannelSelected = 9
            ElseIf cboBoxChannels.Text = "10" Then
                ChannelSelected = 10
            ElseIf cboBoxChannels.Text = "11" Then
                ChannelSelected = 11
            ElseIf cboBoxChannels.Text = "12" Then
                ChannelSelected = 12
            ElseIf cboBoxChannels.Text = "13" Then
                ChannelSelected = 13
            ElseIf cboBoxChannels.Text = "14" Then
                ChannelSelected = 14
            Else : ChannelSelected = 15
            End If
            Select Case ChannelSelected
                Case 6
                    myTask.AIChannels(lblCh6Wfg.Text).Minimum = min
                    myTask.AIChannels(lblCh6Wfg.Text).Maximum = max
                        myTask.AIChannels(lblCh6Wfg.Text).CustomScaleName = "Linear Scale"
                    ElseIf chkBoxTblScale.Checked = True Then
                        myTask.AIChannels(lblCh6Wfg.Text).CustomScaleName = "Table Scale"
                        myTask.AIChannels(lblCh6Wfg.Text).CustomScaleName = "Ranged Map Scale"
                    End If
TblScale = Nothing
RMPScale = Nothing
LinScale = Nothing
Thank you
(4,200 Views)
Accepted by busarider29
Watch what you are doing with the New .
If the object doesn't exist then you want to create it, but once it is created, you should be modifying it.
(4,188 Views)
