Highlighting area in a graph
Is there any way I can highlight areas in a graph.
Almost like when zooming using InteractionMode = ZoomX, except I do not want to zoom, just having the area remain highlighted.
(4,233 Views)
Have you looked at range annotations as an option? If they don't fit your needs, can you let us know why not/what is missing?
David Rohacek
(4,220 Views)
OK, maybe I can use those. Is there any way I can create them at runtime and let the user drag out the position and size?
(4,203 Views)
That functionality is not built into the annotations. I can think of a few options:
1) Use cursors to allow the end user to specify the location and dimensions of a range annotation
2) Use an Instrument Control Strip to allow the end user to specify the location and dimensions of a range annotation
3) Implement the mouse dragging & click functionality yourself
David Rohacek
(4,185 Views)
Check out the examples located at this post as they might be of some use.
Best Regards,
Jonathan N.
(4,167 Views)
