06-22-2017 10:11 AM - edited 06-22-2017 10:12 AM
I can get devices and modules' physical channel (I use cDAQs) but I wonder if there is any way to get what these cDAQ devices are?
"Dev1" --> NI 9074, cDAQ Modules: NI 9225, NI 9227
"Dev2" --> NI 9078, cDAQ Modules: NI 9234, NI 9234
Solved! Go to Solution.
06-23-2017 09:43 AM
Hey rle2,
I found a way to do this! I am basing it off of this example that shows how to do it in LabVIEW:
https://forums.ni.com/t5/Example-Programs/Get-cDAQ-Module-Types-in-LabVIEW/ta-p/3520083
I have a cDAQ chassis called "cDAQ3", and this code successfully prints out the type of all of the modules in the chassis:
Device dev = DaqSystem.Local.LoadDevice("cDAQ3");
string [] module_names = dev.ChassisModuleDeviceNames;
foreach (string module_name in module_names)
Device module = DaqSystem.Local.LoadDevice(module_name);
string type = module.ProductType;
Console.WriteLine(type);
Cheers,
Ryan C.
