How can I identify my task/ how do I get the task name? (C#)
although I am quite new to prgramming in C# and DAQ, I am trying to create a software which programmatically creates task, add channels, st timing parameters and dispose the task after use (lifetime of a task is about 4 weeks). As I need multiple Tasks I am using an array of Tasks but can't find a way to identify a certain task (except for its index in the array). As you can set the name of the Task via constructor "Task (string name)", I thought there should be a way to get the name in order to get the right array index for manipiulationg the task. Or can anyone think of a different way how to identify a task? (btw: i am not using Measurement Studio)
Thanks in advance
Andreas
(4,396 Views)
You could save your created tasks to the Measurement and Automation Explorer (MAX). If you do so, you can get an Array of Tasknames saved in MAX:
            string[] TaskNames;
            Task myTask = new Task("MyFirstTask");
            myTask.AIChannels.CreateVoltageChannel("Dev3/ai0", "TestChannel", AITerminalConfiguration.Differential, 0.0, 10.0, AIVoltageUnits.Volts);
            DaqSystem.Local.SaveTask(myTask);
            TaskNames=DaqSystem.Local.Tasks;
Hope this helps!
André
(4,387 Views)
Thanks for your answer! Unfortunately, the programme should run without supervision for several weeks, so the Tasks are to be created automatically. Thats also the reason, why I want to access the Tasks by some kind of identification, either Name or Number..
[edit]: maybe I should read the code as well 😉
This is worth a try, and its even a good oppurtunity to watch which tasks are active and which ressources have to be released. Thank you.
Message Edited by Lunarfur on 07-30-2007 10:49 AM
(4,379 Views)
