Programmatically open DAQ assistant
Hello!
I am making an application which allows the user to configure multiple analog channels and then record data from them. After a ton of work on my channel configuration window, I realized I could just load a task from MAX instead of writing my own configuration window.
What I’d like to do is replace my configuration window with the DAQ assistant wizard. (It would create/modify a task I could load in my application.) Does anyone know how to programmatically call the wizard?
Thanks!
Ben
(3,523 Views)
 Hi Ben,
 I don't think you can programatically call the DAQ Assistant, you can however create tasks programatically. If you get creative you might be able to leverage that into the functionality you are looking
 Take a look at this link, then this one.
What feature set are you looking for specifically? If it's just analog input then it's a lot easier.
MatthewW
(3,501 Views)
