How do I fix error with installed package: "could not load file or assembly" NationalInstruments.Daqmx.dll
I have been fighting this problem for days (understatement).....
I have an installation package that used to work but now does not.  I have tried installing and running the program on a couple computers and the program crashes when loading the NI Dll's.  I have everything set to 'x86.
The dependency list in VS2010 is shown in the attatched screen shot.
The error text from attempting to run the app on the target machine is below in italics.
I sure could use some help on this!!!  Thanks in advance.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'NationalInstruments.DAQmx.dll' or one of its dependencies. The specified module could not be found.
File name: 'NationalInstruments.DAQmx.dll'
at IPClientTest.MTF_Supervisor.mainSstart13()
at IPClientTest.MTF_Supervisor.mainStartByParts()
at IPClientTest.MTF_Supervisor.lblSelfTest_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Label.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34011 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
MTF_Supervisor
Assembly Version: 1.0.3.3
Win32 Version: 1.0.3.03
CodeBase: file:///C:/mtfDebug/MTF_Supervisor.exe
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
MTF_ClassLib
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
CodeBase: file:///C:/mtfDebug/MTF_ClassLib.DLL
NationalInstruments.UI.WindowsForms
Assembly Version: 13.0.40.242
Win32 Version: 13.0.40.242
CodeBase: file:///C:/mtfDebug/NationalInstruments.UI.WindowsForms.DLL
CodeBase: file:///C:/mtfDebug/NationalInstruments.UI.DLL
NationalInstruments.Common
Assembly Version: 13.0.40.188
Win32 Version: 13.0.40.188
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/NationalInstruments.Common/v4.0_13.0.40.188__dc6ad606294fc298/NationalInstruments.Common.dll
System.Web
Win32 Version: 4.0.30319.34009 built by: FX45W81RTMGDR
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
NationalInstruments.Common.Native
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_32/NationalInstruments.Common.Native/v4.0_13.0.40.188__dc6ad606294fc298/NationalInstruments.Common.Native.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Design
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Accessibility
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
(10,611 Views)
Hi Lorne.V.
Seems that this can help you to solve your issue!
Regards
Chris S.
(10,582 Views)
I wish that was the fix.  I do already have  ".NET framework 4.0 language support"  installed.
(10,580 Views)
Accepted by Lorne.V.
Hi Lorne.V.,
How exactly are you installing NI DAQmx on the target machines?  Even if you include the DAQmx merge module in your build, you will still need to install DAQmx on the target machine separately.
Can you also confirm that the DAQmx.dll is installed in the same directory on both the development and deployment machines?  And that you have the same version of DAQmx on both machines?
(10,563 Views)
Thanks.  That could be the problem.  I'll post an update when I get a chance to test it.
Lorne.
(10,557 Views)
System.Security.Cryptography.CryptographicException: Padding is invalid and cannot be removed.
   at System.Security.Cryptography.RijndaelManagedTransform.DecryptData(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount, Byte[]& outputBuffer, Int32 outputOffset, PaddingMode paddingMode, Boolean fLast)
   at System.Security.Cryptography.RijndaelManagedTransform.TransformFinalBlock(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount)
   at System.Security.Cryptography.CryptoStream.FlushFinalBlock()
   at System.Security.Cryptography.CryptoStream.Dispose(Boolean disposing)
   at System.IO.Stream.Close()
   at MindTech.clsConfig.AES_Decrypt(Byte[] bytesToBeDecrypted, Byte[] passwordBytes)
   at MindTech.clsConfig.DecryptText(String input, String password)
   at MindTech.frmClientMaster.AddRecord(DataTable dt, DataSet ds)
   at MindTech.frmClientMaster.btnShowReport_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
mscorlib
DMIT
    Assembly Version: 1.0.0.7
    Win32 Version: 2.0.1.5
    CodeBase: file:///D:/DMIT%20MAIN%20Software/test/DMIT.exe
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
DocumentFormat.OpenXml
    Assembly Version: 2.0.5022.0
    Win32 Version: 2.0.5022.0
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/DocumentFormat.OpenXml/2.0.5022.0__31bf3856ad364e35/DocumentFormat.OpenXml.dll
WindowsBase
    Win32 Version: 4.0.30319.34004 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
How to fix that error?
(6,111 Views)
