‎02-12-2007 09:54 AM
‎02-16-2007 05:37 AM
‎02-17-2007 10:39 AM
Hi James,
I was looking for the helps for the (DAQ) .Net class libraries for driving a PXI-6259 card. Normally when an installation adds a help file to the Visual Studio combined help collection, it is immedately available for use. You sometimes have to go looking for it in the "Filtered by:" drop-down list box, but following the installation of the version 8.0.1 drivers there was no sign of it. It happily appeared in the Dev Studio 2003 help system when installed onto a PC containing Dev Studio 2003 only, and it also appeared in the 2003 version when installed onto a machine with both 2003 & 2005 version installed.
I eventually found out that one has to use the "Visual Studio 2005 Combined Help Collection Manager" to manually add the National Instruments help to the Visual Studio 2005 helps. There's a link from the front page of the help system when you open it from the Start menu (rather than opening it from within Visual Studio 2005).
Thank you for replying anyway.
Regards
David Razzetti
‎02-19-2007 10:11 AM
