How to access COMM port
I don't seem to find any information about accessing COMM ports (RS-232) under 7.0 .NET. Anyone knows how to do it? Thanks.
(4,410 Views)
The .NET framework does not directly support serial communication. You can use the Win32 SDK through platform invoke (P/Invoke) calls, or you can use the VisaNS .NET class library form National Instruments, which supports serial communication. You can install the Visa .NET support from the National Instruments Driver CD
(4,405 Views)
There is a free component from SAX for RS-232.
http://www.sax.net
Why do the links not work in this forum?
(4,405 Views)
I presume you have not installed the NI-VISA driver. If you download (from NI web) and install it site you will be able to access the COM port.
It must have been supplied as a driver CD with measurement studio.
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BAC002C51FA?opendocument&node=132070_US
(4,228 Views)
MSDN has an article on how to use the P/Invoke with .NET.
http://msdn.microsoft.com/msdnmag/issues/02/10/netserialcomm/
MSDN also has a great article on using RS-232 with .NET.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dncodefun/html/code4fun12102003.asp
They show samples interfacing with an RS-232 LCD controller. The article mentions a component called DBComm that I have been using for over six months with a lot of success.
Finally RS-232 is supposed to be supported in the next release of .NET (Whidbey).
(4,185 Views)
This is the standard ActiveX control as used my VB programmers.
The SAX control is a free DOTNET control so P/Invoke is not needed.
(4,171 Views)
