How to add annotations to scattergraph?
It seems to be simple Smiley Happy(sur it will be), but i spent 2 hour trying to add an annotation to a scattergraph.
It's working perfectly in design mode, but i want to do it by code, something like this:
 Dim ann As New XYAnnotationCollection
ScatterGraph1.Annotations.Add(ann)
But this is not working, ann is a XYAnnotationCollection not a XYAnnotation. And when i declare it as XYAnnotation, it wont work too, (mustinherit class)!!!
Using VB 2005
Thank's in advance.
(4,697 Views)
A quick tip is you can always see the code that is made during Design mode in your code by just unhiding the "Required by the Windows Form Designer" code at the beginning of your program. Here if we make an annotation we can see how VS codes it and copy their syntax.
Me.XyPointAnnotation1 = New NationalInstruments.UI.XYPointAnnotation
Me.ScatterGraph1.Annotations.AddRange(New NationalInstruments.UI.XYAnnotation() {Me.XyPointAnnotation1})
Me.XyPointAnnotation1.Caption = "XyPointAnnotation1"
Me.XyPointAnnotation1.CaptionAlignment = New NationalInstruments.UI.AnnotationCaptionAlignment(NationalInstruments.UI.BoundsAlignment.None, 0.0!, 25.0!)
Me.XyPointAnnotation1.XAxis = Me.XAxis1
Me.XyPointAnnotation1.XPosition = 1
Me.XyPointAnnotation1.YAxis = Me.YAxis1
Me.XyPointAnnotation1.YPosition = 9
It sounds like you may not be initalizing thethe annotation correctly.
Steven Zittrower
Applications Engineer
http://www.ni.com/support
(4,678 Views)
Accepted by ELBOB
Thanks For The Tip. Really helpfull.
If it can help someone else, I got it work by using a clone of the first annotation -wich was made by design and invisible-
Dim ann As XYPointAnnotation
For i = 0 To Nmax
ann = frmsuivi_tendance.XyPointAnnotation1.Clone()
ann.Visible = True
next i
(4,659 Views)
