How to control which 2nd timer is used for finite pulsetrain generation
I am generating a finite pulsetrain with the following code:
myTask = New Task(String.Empty)
mNIClockChannel = myTask.COChannels.CreatePulseChannelFrequency(mClockChannelName, _
String.Empty, COPulseFrequencyUnits.Hertz, COPulseIdleState.Low, 0.0, _
mFrequency, 0.5)
myTask.Timing.ConfigureImplicit(SampleQuantityMode.FiniteSamples, HowFar)
myTask.Start()
It appears to use the timer that I specify in the variable 'mClockChannelName' for the pulses, and an unspecified 2nd timer to count the pulses.
Is there a way to explicitly pick which timer the code will use for the pulse bookkeeping?
(3,082 Views)
Hello Anatoly2,
Thank you for contacting National Instruments.
When you set up a finite pulse train like this, NI-DAQmx automatically assigns the output counter's pair as the gating counter (i.e. counters 0&1, 2&3, etc...).
The only way to specify which counter you wanted to gate the output would be to manually set up the finite counter configuration. You would set one counter to output a continuous pulse train and another counter to output a single pulse whose length equals the length of time it takes to generate X pulses on the output counter. Then use the single pulse as a gate for the finite pulse train counter.
Sincerely,
Sean C.
(3,066 Views)
