How to extract the plot from a graph ?
I m currently trying to add a capture button to a graph. The datas are added (charting) in real-time to the graph and the capture would copy (ploting) the plot to an other graph. Can I do that or should I better keep a copy of the points to be able to plot them ?
Thank you for helping
(3,428 Views)
You can use the GetXData and GetYData methods on the plot to get the data from the plot, then you could plot that data on a plot in another graph. For example, if you're using the WaveformGraph, you could do this:
double[] data = sourcePlot.GetYData();
targetPlot.PlotY(data);
Similarly, if you're using the ScatterGraph, you could do this:
double[] xData = sourcePlot.GetXData();
double[] yData = sourcePlot.GetYData();
targetPlot.PlotXY(xData, yData);
- Elton
(3,420 Views)
