How to get the y-values from all plots of WPF Graph at the same known x-value?
Hi all!
WPF question.How to get the y-values from all plots of WPF Graph at the same known x-value (got the x-value from textbox)?
Thanks!
(5,172 Views)
Accepted by mengly
You can use the FindNearestValues method to find the data values corresponding to a specified axis intercept across multiple plots. This method takes a relative value, so you will want to convert your raw data value using DataToRelative first. For example:
    var xAxis = ...;
    double relativeValue = graph.DataToRelative( xAxis, xValue );
    var query = new GraphQueryArgs( PlotsToSearch.Any, SearchDimensions.Horizontal, SearchDirections.ForwardAndReverse, isInclusive: true );
    var foundValues = graph.FindNearestValues( xAxis, relativeValue, query );
    foreach( PlotValue found in foundValues ) {
        object x = found.Value[0];
        object y = found.Value[1];
~ Paul H
(5,163 Views)
Thanks a lot Paul. It works like a charm.
(5,158 Views)
