How to put the scaling for more than one channels in only one Y-axis for stacking the plots like in the example "Graph Example" in the Measurement Studio Reference
how can I put the scaling for more than one channels in only one Y-axis for stacking the plots like in the example "Graph Example" in the Measurement Studio Reference. The normal way is to use some more Y-axis. But the space saving way would be to build a custom-Y-axis, to show the values like this:
10
  5
  0
 -5
-10
10
  5
  0
 -5
-10
This is a simple example. It should be possible too, to use some different units like ±10V and ±100°C on one axis.
Is this possible?
(3,040 Views)
I don´t think that this is possible in a direct and easy way. the best would be to use multiple plots, and format them in a way that you can allign them directly togehter with no free space between them, then it will look like a single graph with multiple vertikal alligned y-Axis...
Does anyone else have a better idea?
(3,034 Views)
