01-26-2018 03:49 AM
Hello
Is there an example how in C# to route a sample clock out to a PFI port? The manual stated it is possible but not how.
I uses two PCIe 6553 cards where i want to shift data in and out with the same clock. This signal needs also clocks an external devices.
The cards are with RTSI connected.
The following code is a first step to try to make it works, it use only the inputs of both cards.
In this sample the tasks start reading with a BeginReadWaveform. Is it possible to start all tasks at the same time?
void SampleAllInputs()
List<string> digitalInputAChannels = new List<string>() { "/dev1/port0/line0" };
List<string> digitalInputBChannels = new List<string>() { "/dev1/port0/line0, /dev1/port0/line1" };
List<string> analogInputAChannels = new List<string>() { "/dev1/ai0" };
List<string> analogInputBChannels = new List<string>() { "/dev1/ai0" };
Task digitalInputATask = null;
Task digitalInputBTask = null;
Task analogInputATask = null;
Task analogInputBTask = null;
rate = 1000;
_samplesPerChannel = 1000;
double bufferSize = rate * _samplesPerChannel;
try
digitalInputATask = new Task("digitalInputATask");
digitalInputBTask = new Task("digitalInputBTask");
analogInputATask = new Task("analogInputATask");
analogInputBTask = new Task("analogInputBTask");
foreach (var item in digitalInputAChannels)
digitalInputATask.DIChannels.CreateChannel(item, "", ChannelLineGrouping.OneChannelForEachLine);
foreach (var item in digitalInputBChannels)
digitalInputBTask.DIChannels.CreateChannel(item, "", ChannelLineGrouping.OneChannelForEachLine);
foreach (var item in analogInputAChannels)
analogInputATask.AIChannels.CreateVoltageChannel(item, "", AITerminalConfiguration.Rse, -10, 10, AIVoltageUnits.Volts);
foreach (var item in analogInputBChannels)
analogInputBTask.AIChannels.CreateVoltageChannel(item, "", AITerminalConfiguration.Rse, -10, 10, AIVoltageUnits.Volts);
analogInputATask.Timing.ConfigureSampleClock("", rate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, _samplesPerChannel);
analogInputBTask.Timing.ConfigureSampleClock("/dev1/ai/SampleClock", rate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, _samplesPerChannel);
digitalInputATask.Timing.ConfigureSampleClock("/dev1/ai/SampleClock", rate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, _samplesPerChannel);
digitalInputBTask.Timing.ConfigureSampleClock("/dev1/ai/SampleClock", rate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, _samplesPerChannel);
analogInputATask.Control(TaskAction.Verify);
analogInputBTask.Control(TaskAction.Verify);
digitalInputATask.Control(TaskAction.Verify);
digitalInputBTask.Control(TaskAction.Verify);
AnalogMultiChannelReader analogMultiChannelReaderA = new AnalogMultiChannelReader(analogInputATask.Stream);
AnalogMultiChannelReader analogMultiChannelReaderB = new AnalogMultiChannelReader(analogInputBTask.Stream);
DigitalMultiChannelReader digitalMultiChannelReaderA = new DigitalMultiChannelReader(digitalInputATask.Stream);
DigitalMultiChannelReader digitalMultiChannelReaderB = new DigitalMultiChannelReader(digitalInputBTask.Stream);
AsyncCallback analogSamplingCallbackA = new AsyncCallback(OnAnalogSampling);
AsyncCallback analogSamplingCallbackB = new AsyncCallback(OnAnalogSampling);
AsyncCallback digitalSamplingCallbackA = new AsyncCallback(OnDigitalSampling);
AsyncCallback digitalSamplingCallbackB = new AsyncCallback(OnDigitalSampling);
analogMultiChannelReaderA.SynchronizeCallbacks = true;
analogMultiChannelReaderB.SynchronizeCallbacks = true;
digitalMultiChannelReaderA.SynchronizeCallbacks = true;
digitalMultiChannelReaderB.SynchronizeCallbacks = true;
analogMultiChannelReaderA.BeginReadWaveform(_samplesPerChannel, OnAnalogSampling, analogInputATask);
analogMultiChannelReaderB.BeginReadWaveform(_samplesPerChannel, OnAnalogSampling, analogInputBTask);
digitalMultiChannelReaderA.BeginReadWaveform(_samplesPerChannel, OnDigitalSampling, digitalInputATask);
digitalMultiChannelReaderB.BeginReadWaveform(_samplesPerChannel, OnDigitalSampling, digitalInputBTask);
catch (DaqException exception)
if (digitalInputATask != null) { digitalInputATask.Dispose(); }
if (digitalInputBTask != null) { digitalInputBTask.Dispose(); }
if (analogInputATask != null) { analogInputATask.Dispose(); }
if (analogInputBTask != null) { analogInputBTask.Dispose(); }
void OnAnalogSampling(IAsyncResult ar)
var task = ar.AsyncState as Task;
if (task == null) { return; }
try
AnalogMultiChannelReader reader = new AnalogMultiChannelReader(task.Stream);
AnalogWaveform<double>[] data = reader.EndReadWaveform(ar);
reader.BeginReadWaveform(_samplesPerChannel, callBack, task);
catch (DaqException daqException)
task.Dispose();
task = null;
void OnDigitalSampling(IAsyncResult ar)
try
DigitalMultiChannelReader reader = new DigitalMultiChannelReader(task.Stream);
DigitalWaveform[] data = reader.EndReadWaveform(ar);
reader.BeginReadWaveform(_samplesPerChannel, OnDigitalSamplingA, task);
task.Dispose();
task = null;
Solved! Go to Solution.
01-31-2018
03:11 AM
- last edited on
10-09-2025
08:59 AM
by
Content Cleaner
Unfortunately I cannot program in C# however I have found the following that may be useful to you:
https://forums.ni.com/t5/Counter-Timer/Route-Sample-Clock-Through-External-PFI/td-p/3275871
I hope these are of use to you,
Amy
02-02-2018 02:53 AM
Hi Amy,
Thank for your post. It helps me a lot.
Regards
