In LV7.1 how can I use a command from a .Net .DLL file that requires an input from .NET class TimeSpan?
I am currently using LabView 7.1 to control an instrument using a .NET 2.0 compatible API.  A dispense command requires that I set the dispense timeout.  The command is expecting a standard .Net class but when I create a constant I just get a dog eared piece of paper that says .NET.  I cannot see a way to set this value.  How can I send the proper value to this command?
(4,174 Views)
Accepted by topic author JasonHamilton
Hello Jason
The timestan is inside the mscorlib.dll, in order to use it you have to create a contructor node and select the mscorlib as show in the image this will create the reference you need:
to locate the timestan  open +system and search for it, then you just have to create a .net property or invoke node to access the properties or the methods of the timestan object:
Martin Garcia
National Instruments Corp.
(4,165 Views)
Thank you very much.  Once I finally found the correct version of the file everything seems to work great!
(4,154 Views)
