IntensityGraph with 2D array of Point3D
Hey there,
I am trying to implement an Intensity graph which has a 2D-Array of Point3D as DataSource (as mentioned for example here). It works to set the DataSource, but it seems that my X-values are not used.
My Array is initialized like this:
Point3D[,] pdData = new Point3D[resolutionX,resolutionY];
I then iterate through the whole array multiple times and increment the Z-value depending on my input data. Debugging lets me see that the 3D-points have the values as I want them (this has been reduced to 4x4, later this would be much bigger, but shows the same behaviour):
My intensity graph then looks like this:
From the Scale I can see that only the values from the first row are plotted (pdData[0,:]). What am I missing here?
Thanks in advance
(3,150 Views)
Accepted by mrpip
I have not had a chance to debug this locally yet, but I expect the problem is that you are sending a 2D array of 3D data, and the graph is not interpreting the added structure correctly.
Instead of using Point3D[,] pdData = new Point3D[resolutionX, resolutionY] for your data, try Point3D[] pdData = new Point3D[resolutionX * resolutionY]. (You could also try assigning graph.Data[0] = Point3D[,] directly, which would avoid the interpretation logic performed by DataSource.)
~ Paul H
(3,134 Views)
As usual, thank you so much Paul! 🙂
(3,111 Views)
