Internal Software Error occured in CPP_API software. Requested Code -2147220693 Status Code: -224803
I have a small program that waits for a digital trigger and then reads from a channel. Using an NI-USB-6212. Everything works fine, except sometimes the program will fail to start. On debugging I see that the first line that interacts with the DAQ hangs. In this case it is 'DaqSystem.Local.GetPhysicalChannels(PhysicalChannelTypes.AI, PhysicalChannelAccess.External)'. Recently I was able to get the above error in Visual Studio. The only solution appears to be restarting the computer. This is obviously not ideal.  Any ideas?
-Matt
(5,913 Views)
Hello Matt,
Please go ahead and download the following example from our website.
https://forums.ni.com/t5/Example-Code/Archived-NI-DAQmx-Continuous-Analog-Input-with-Both-Start-and/...
This example program shows you how to continuously acquire data (a waveform) using an internal clock and a digital start and reference trigger.
Please use it as a reference.
Regards
Luis S
Application Engineer
(5,888 Views)
