i installed NI-DAQmx 9.8 full version and i can not find the NationalInstruments.DAQmx.dll file to include in my project.
The last version I had installed was 9.3 athe .DAQmx.dll was included.  Now, in my "C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\13.0.40.190" path, or any other, it is not there.  ONly the .Common.dll is there.
I use VS2010.
Does anyone know why it was not installed and how I get in installed?  All my previouse code needs this assembly.  (anything previously using the NationalInstruments.DAQmx namespace)
Thank you
Joe
(6,386 Views)
Joe,
did you run a customized installation or the standard one? It sounds to me that the .NET interface wasnt installed on your system.
Norbert
Norbert
Expert: Geometry
(6,369 Views)
i ran standard.. but i guess i will uninstall and try again....  maybe i was zoning out during the install.. ill update after.  thanks,
Joe
(6,355 Views)
modified installation... had to select to install this... i swear that used to be the default... anyway it works!
thanks,
joe
(6,354 Views)
I have the same pb. After the standard installation VB.net not found DAQmx.dll.
It 's delevry with Measurement studio ( I not have this) or this file it with the Ni-DAQmx 9.8 full version driver ?
Without DAQmx.dll the import is not working.
Thank for your help.
(6,346 Views)
