 jtaki
			jtaki
			10-06-2013 03:35 PM - edited 10-06-2013 03:35 PM
The last version I had installed was 9.3 athe .DAQmx.dll was included. Now, in my "C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\13.0.40.190" path, or any other, it is not there. ONly the .Common.dll is there.
I use VS2010.
Does anyone know why it was not installed and how I get in installed? All my previouse code needs this assembly. (anything previously using the NationalInstruments.DAQmx namespace)
Thank you
Joe
 Norbert_B
			Norbert_B
			10-07-2013 07:48 AM
Joe,
did you run a customized installation or the standard one? It sounds to me that the .NET interface wasnt installed on your system.
Norbert
10-07-2013 05:02 PM
i ran standard.. but i guess i will uninstall and try again.... maybe i was zoning out during the install.. ill update after. thanks,
Joe
10-07-2013 05:14 PM
modified installation... had to select to install this... i swear that used to be the default... anyway it works!
thanks,
joe
 Cptjack
			Cptjack
			10-08-2013 12:32 PM
I have the same pb. After the standard installation VB.net not found DAQmx.dll.
It 's delevry with Measurement studio ( I not have this) or this file it with the Ni-DAQmx 9.8 full version driver ?
Without DAQmx.dll the import is not working.
Thank for your help.
