Is Imports NationalInstruments.DAQmx still the first statement in a VB2010 programme?
I had good results with VB2005 and WindowsXP but having upgraded to Window7 We need to use VB2010 to operate the USB6008.
When I type Imports NationalInstruments.DAQmx at the very top there's a sqiggly underline in green with pop-up to the effect that this is the wrong Namespace or the file cannot be found.
I remain in due course corrected please.
Message 1 of 15
(7,148 Views)
You need to add a reference to the DAQmx library.
Curt
Message 2 of 15
(7,127 Views)
Thanks for your reply.
I have made reference to:
CW3DGraphLib
MXCTRLib
NI.Common.Native
NI.MStudioCLM
NI.NiLMClientDLL
NATUPNPlib
NIDAQmxCAPI
NIReports
nisysapi
Still the sqiggly green line under NationalInstruments.DAQmx
Does this list at least contain the correct reference?
Maybe I must change something in the Properties Window?
Look forward to your reply Sir
jeff
Message 3 of 15
(7,123 Views)
You should see the NationalInstruments.DAQmx NET library listed. See attached image.
Curt
Message 4 of 15
(7,106 Views)
When you installed the NI-DAQmx driver software, was Visual Studio 2010 already installed?
If not, you may need to go back to and repair the install or re-install of NI-DAQmx to add support for .NET 4.0
I only have VB.NET 2010 Express. Once I added the reference to NI-DAQmx, C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\Current\NationalInstruments.DAQmx.dll, everything was fine.
Message 5 of 15
(7,097 Views)
Thanks for telling me that information.Vital.Problem solved.
Maybe you can tell me that the DLL is the same one I had success with on VB2005 and that all the statements relating to the USB 6008 are the same.Once again many thanks
Message 6 of 15
(6,966 Views)
You should post some of your code. It looks like you were using Measurement Studio 6.0 Active X controls.
The code for .NET calls to DAQmx will be different.
Curt
Message 7 of 15
(6,964 Views)
Well I managed to make reference to
NationalInstruments>DAQmx  and
NationalInstruments.Common.
and no errors in the editor till i build then:
"The referenced assemblies could not be resolved because it has a dependency on System Web Version 4 .0.0.0 which is not in the currently targeted frame work .NET Framework Version 4.
After the build all squiggly green underline back by NationalInstruments.DAQmx..
I installed .Net Framework 4 after i installed VB2010.
Dear Curt,
Do you have any idea?
regards
jeff
Message 8 of 15
(6,892 Views)
Please see the comments I made above
I referenced NationalInstruments.DAQmx  and
and the squigtgly green line under NationalInstruments.DAQmx goes away.
but when I Build it comes back with the msg
"The referenced assemblies could not be resolved because it has a dependency on System.Web Version 4.0.0.0
which is not in the currently targeted framework  .Net Framework 4...."
Do you have any ideas
regards
jeff
Message 9 of 15
(6,881 Views)
Hi Jeff,
The System.Web reference could have been added by any number of components that you included in your project. Did you add a Measurement Studio 'NetworkVariableDataSource' or 'NetworkVariableBrowserDialog' your project?
Curt
Message 10 of 15
(6,857 Views)
