port vb.net with measurement studio to mac
Does anyone know a path to porting a VB.net application which uses measurement studio to a mac?
Also, if I were to create a labview application instead, would that easily port to a mac?
bartj
(5,640 Views)
The easier is to use LabVIEW.
(5,638 Views)
bartj,
do you still plan to make .net calls if you opt to create a labview application? if so, you'd still run into issues porting to a mac os. here's more information on porting vis among platforms:
https://www.ni.com/docs/en-US/bundle/labview/page/porting-vis-among-platforms.html
another option would be to trying using the mono framework. it is software platform designed to help create cross platform applications
http://www.mono-project.com/Main_Page
(5,606 Views)
Do you know if anyone has had sucess using the mono framework while incorporating measurement studio in the project? Specifically the measurement studio graph control is of interest.
bartj
(5,598 Views)
bartinoregon,
I just looked futher into incorporating the mono frameowrk with measurement studio and it turns out the two are not compatible. The underlying DLL called to perform the appropriate functionality is a C++ library not compatible with Mono. I apologize for the misleading information in my previous message.
(5,583 Views)
