Is there a manusal avaialble, which I can refer to while programming?
Hi all. I am trying to design a software for Data Acquisition. I intend to use VB 6 or  2008, and Measurement Studio (never used before). Can you please let me know if I can find a reference manual or anything, which might help me to understand the tools and properties of Measurement Studio.
Thank you in anticipation.
(3,476 Views)
1. Install Measurement Studio for your IDE (e.g., VS2005)
2. Navigate to the help directory (therein, you'll find Measurement Studio User Manual.pdf)
The online-help is good as well.
Highlight a keyword, and press F1.
Hope this helps, C
(3,461 Views)
Also, when you are installing DAQmx, be sure to include support for the .NET framework version you will be targeting.  This will install a large number of very helpful example programs.  The locations of these examples can be found in the KnowledgeBase NI-DAQmx, NI-VISA and NI-488.2 .NET Example Locations.  These examples have been built to demonstrate most of the normal requirements of a Data Acqusition program, and are easily modified to meet your needs.
NickB
Applications Engineering
(3,455 Views)
