 JohanSalomonsso
			JohanSalomonsso03-09-2021 02:48 PM
Hi
Is there any way to filter a signal from a NI 9237 that are used for measure a loadcell.
My settings are.
SampleRate = 10000;
SamplesPerChannel = 1000;
The channel is set up as a StrainGageChannel
I get at signal that have a diff off -+50 gram and does not look good. see attached png-file
I'm trying to measure a signal that I do a fft on and try to determine a frequency of 100 Hz
Is there any filter that I can add to get a cleaner signal?
/Johan
03-16-2021 11:49 AM
Hi Johan,
Have you seen the article Wiring considerations for the NI 9237 module?
Please can you check you are using a NI 9949 and that you have wired it up correctly for your bridge configuration which is set in NI-MAX. Full wiring diagrams can be found from page 12 of the Getting Started Guide. This is mostly to be the source of the noise on the signal.
I hope that helps!
Alice
