MS Online Help
I am looking for manual, online documentation, class library reference or a simple chm file for the followings:
  • NationalInstruments.Common
  • NationalInstruments.DAQmx
I have been looking forward it but I can not find anything....
In Visual Studio under the Online help I have the following link:http://msdn.microsoft.com/query/dev10.query?appId=Dev10IDEF1&l=EN-US&k=k(FUSINGNIMSTUDIOHELP)&rd=tru...
Any ideas?
+++ In God we believe, in Trance we Trust +++
[Hungary]
(5,759 Views)
Unfortunately, the link you provided does not work. First of all, it is good to install DAQmx drivers and enable to install support for text-based languages, help will install too.
Some of the resources about NationalInstruments namespace can be found on http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/c9bb7f7e/ , DAQmx help is accessible through Start > All Programs > National Instruments > NI-DAQ > Text-based Code Support, where you can search for desired info. There is also KnowledgeBase about locations for DAQmx .NET help files https://www.ni.com/en/support/documentation/supplemental/17/ni-daqmx-for-windows-documentation-locat... . If the help files will not be accessible after install, follow https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LuqSAE&l=en-US .
Martin
(5,734 Views)
