Measurement Studio 8.0 Patch for Visual Studio 2005
Greetings all
We have a patch available for issues that were reported when trying to use Measurement Studio 8.0 .NET libraries from Visual Studio 2005.
The issues are as follows:
  • PropertyEditor control throws a NullReferenceException when dropped in Visual Studio 2005.
  • If you add an item to collection editors of UI controls at design-time and cancel the collection editor dialog, you receive an error stating that an ObjectDisposedException has been thrown. This error does not cause the component to behave improperly. The control can still be used without any problems after the error is generated.
  • NumericEdit control does not draw a border in Visual Studio 2005.
  • If you have only Visual Studio 2005 installed, Visual Studio 2005 generates warnings when building setup projects consisting of the NationalInstruments.UI or NationalInstruments.UI.WindowsForms assemblies.
You must download and install the patch to fix the issues in the Measurement Studio 8.0 .NET controls to support Visual Studio 2005 and the .NET Framework 2.0. Refer to the link below for information about downloading and installing the patch.
Issues with Measurement Studio 8.0.0 and Microsoft Visual Studio 2005
http://digital.ni.com/public.nsf/websearch/79C8C738C1183FE1862570C200007A61?OpenDocument
You do not need this patch if you are using Visual Studio 2003 only. This patch is only for the Measurement Studio 8.0 .NET class libraries.
Thank You
Bilal Durrani
NI
Bilal Durrani
NI
Message 1 of 1
(4,100 Views)
