Measurement Studio 8.6.1: NationalInstruments.Restricted.AnalysisLicenser is unlicensed.
We are building a service which performs calculations using NationalInstruments.Analysis.Professional and NationalInstruments.Common.  We have a valid license for Measurement Studio 8.6.1.  Our project can be built and deployed successfully, but recently when running the application we are seeing the following exception being thrown.  My best guess is that something isn't being configured correctly at build-time but I'm not sure what can be done to correct the issue.  Any help would be appreciated.
      at System.ServiceModel.Channels.ServiceChannel.ThrowIfFaultUnderstood(Message reply, MessageFault fault, String action, MessageVersion version, FaultConverter faultConverter)
     at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
     at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
     at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs)     at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
     at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
    Exception rethrown at [0]:
      at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
     at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
Greg
(4,619 Views)
Hi Greg,
Are you using Visual Studio 2010?  If so here is a document that shows you how to manually license your frameworks.
Let us know if this helps!
Regards
Dustin D
(4,602 Views)
