Will the NationalInstruments.DAQmx DLL work with Windows CE (.Net compact framework)?
I would like to use the NI USB-6008 device for additional I/O with my device.  I am running Windows CE with the .net compact framework.  When I try to use the NationalInstruments.DAQmx.AnalogSingleChannelWriter.WriteSingleSample() function, it builds without errors.  When I deploy the runtime image on my device I get an error.
My first question is whether this dll supports WinCE and the compact framework.  I have seen some older posts (2002-2006) that say that it was not supported at the time but that it could be supported in the future.  Is it supported yet?
If it is supported, then I am doing something wrong and could use some more detailed help.
Thank you.
(3,398 Views)
Support for Windows CE is found in DAQmx Base, however it supports the LabVIEW API as shown in the readme.  It doesn't look as though .NET support has been implemented yet.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(3,376 Views)
