Measurement Studio WaveFormGraph Axes Captions
Can measurement studio waveform graph axes caption be programmatically modified?  And if not, then why not?
(5,089 Views)
Hi CraigByrd
Yes, you should be able to edit waveform graph axis captions at runtime. Are you using a Windows Form Application or a WPF Application?
Andy F.
Applications Engineering
(5,070 Views)
Thank you for your quick response.
I am developing an NI VISA Windows Application using Visual Studio 2010.
(5,064 Views)
Hi CraigByrd
You should be able to set the property at runtime by typing the following:
<Object instance of your waveform plot here>.XAxis.Caption="Insert Text Here";
Andy F.
(5,019 Views)
Accepted by CraigByrd
Thanks to your solution repsonse I was able solve the problem.
It turns out the X & Y captions were not part of the wave form graph , but rather a separate xAxis1 and yAxis1 were present in the form1.Designer.cs file as shown below:
// wfgPLOT
this.wfgPLOT.Location = new System.Drawing.Point(689, 371);
this.wfgPLOT.Name = "wfgPLOT";
this.wfgPLOT.Plots.AddRange(new NationalInstruments.UI.WaveformPlot[] {
this.waveformPlot1});
this.wfgPLOT.Size = new System.Drawing.Size(754, 337);
this.wfgPLOT.TabIndex = 15;
this.wfgPLOT.UseColorGenerator = true;
this.wfgPLOT.XAxes.AddRange(new NationalInstruments.UI.XAxis[] {
this.xAxis1});
this.wfgPLOT.YAxes.AddRange(new NationalInstruments.UI.YAxis[] {
this.yAxis1});
// waveformPlot1
this.waveformPlot1.XAxis = this.xAxis1;
this.waveformPlot1.YAxis = this.yAxis1;
// xAxis1
this.xAxis1.Caption = "Number of Readings";
// yAxis1
this.yAxis1.Caption = "Measured Value";
Thus the following code provided the solution.
// modifying default wave form graph Axis Caption follows
wfgPLOT.Caption = sTableName;
xAxis1.Caption = plotXlbl;
yAxis1.Caption = plotYlbl;
Thanks Again
Craig
(5,012 Views)
