Measurement & automation explorer. Test panel for simulated device won't launch
You don't have the space after the colon ( : ) right? It should actually be C:\Windows\SysWOW64\nidmfpan.exe /devid:Dev1 but as you can see the forums makes that into a smiley in between 😕
J
Message 11 of 13
(712 Views)
Another quick thought I had! If the test panels do not work, then I believe as a student you would have access to LabVIEW. So would it be possible to use the DAQ Assistant to simply acquire/generate signals on your simulated USB device?
This might help you to get on with your project instead of waiting for the test panels to be fixed.
J
Message 12 of 13
(708 Views)
Hi.
Yes the space in the reply was only due to the smiley:) No space originally.
Yes I will use a daq Assistant for generating signals instead. (Setup is in the end intended for mesurement studio).
Many thanks!
Message 13 of 13
(705 Views)
