Measurements on analog channels should start, when the pulse rate on CTR0 (digital input) is in a defined range, using Measurement studio
I´m uncertain how to use the pins:
I have a pulse signal TTL up to 100kHz
I like to use CTR0 out/source/gate (which one is the external input?) to aquire the pulse rate/sek
For a defined codition Pulse-rate inbetween Rate-low and Rate-high (CTR0 TRUE)
the aquisition on the analog channels should start.
The actual pulse rate shall be aquired as well.
To my understanding the analog aquisition is running in a FIFO and should transfer the measurements when triggered by the counter CTR0 TRUE event.
We don´t get it running using Measurement Studio.
Someone has an idea?
Best regards, the kermit65
(3,774 Views)
you havn't posted, which DAQ-card you have.
You can check in "MAX->My System->devices and interfaces->NI DAQmx/Traditional DAQ->Your Card->Device-connections"
which modules are connected with your outputpins.
I think you have to use PFI8 (Pin 37) to use CTR0 SRC. But this can differ to your card. You can open a "Connector Pinout Table" in your MAX "Pin allocation of device".
Regards
Markus Weigl (NI Germany)
(3,769 Views)
Danke für die Antwort,
es ist die 6071E
Gruss, Martin
(3,767 Views)
Hallo,
unter folgendem Link können sie die Hilfe-Datei für die E-Serienkarte runterladen (haben Sie aber evtl. schon):
http://digital.ni.com/manuals.nsf/websearch/05A25C65C755D8DB86256FD30081687D
Rufen Sie in dieser Hilfe dann "100-Pin Extended AI I/O Connector Pinout" für die Karte 6071E auf.
Dort finden Sie die Belegung für diese Karte.
Auf der NI-Seite können Sie auch nach Beispielen suchen:
http://www.ni.com/devzone/dev_exchange/ex_search.htm
Wählen Sie dort "Measurement Studio" und "Multifunctional DAQ" aus.
Grüße,
Markus Weigl
(3,763 Views)
