problem with fitting a graph
I am developping a program where I need to fit my graphs with some fitting functions, both polynomial, gauss, and non-linear (self-definition of the fitting function).
I use VB.net and measurement studio, and I don't manage to fit a graph (plotXvsY: nor AxCWGraph, nor ScatterGrpah. I tried
CurveFit.PolynomialFit(array1, array2, 2, 0) 'for a polynom of degree2
but nothing happens!!
I tried this too:
AxCWGraph1.PlotY(CurveFit.PolynomialFit(array1, array2, 2, 0))
but there is nothing too....
In other words: how using facilities for fitting a graph??
Thanks a lot for help, I have read a lot of examples, tried a lot of things, and I don't find solution 😞
(4,490 Views)
There is a curve fitting example under "National Instruments\MeasurementStudioVS2003\DotNET\Examples\Analysis\CurveFitting\" folder. Hope it can help you out.
(4,471 Views)
Thanks for your answer. But there is no example "CurveFitting" but only PeakDetector, BasicSignalGeneration, CompositeSignalGeneration, Filtering and Windowing.
(4,457 Views)
Are you using MStudio7.1? I attached the example here anyway.
(4,447 Views)
