NationalInstruments.Common 9.0.40.362 missing
You can manually create the app.config file and add it to your project. See the MSDN article on creating an app.config file: http://msdn.microsoft.com/en-us/library/ms184658.aspx
The config file will look something like this, but you may need to change the version numbers to the ones that make sense in your case.
<?xml version="1.0"?>
<configuration>
<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup>	<runtime>
		<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
			<dependentAssembly>
				<assemblyIdentity name="NationalInstruments.Common" publicKeyToken="DC6AD606294FC298" culture="neutral"/>
				<bindingRedirect oldVersion="0.0.0.0-9.0.40.362" newVersion="9.1.40.159"/>
			</dependentAssembly>
		</assemblyBinding>
	</runtime>
</configuration>
Message 11 of 14
(2,096 Views)
Thanks for the quick response! I have added the configuration file but it still gives the error. I looked at the properties of it and there is no build action. I tried changing it to a couple different things but still get an error. Is there some sort of setting I need to configure in order for the file to actually run or is it just supposed to know that its there?
Chris
Message 12 of 14
(2,094 Views)
As a reference, I am just trying to use the example program titled "SimpleReadWrite.2010". It is a GPIB example that comes with the NI-488.2 install. Any help is greatly appreciated.
Chris
Message 13 of 14
(2,093 Views)
Right-click the project and choose Add >> New Item then navigate to Application Configuration File and create your file that way. This will ensure that the file is created in the correct manner.
Message 14 of 14
(2,088 Views)
