NiGraph autoscale not work when window is not visible
I have NiGraph autoscale function doubt, here is my steps to plot the data on graph window
1. Set graph property
2. Minimize this graph window into taskbar
3. Send data to graph for plotting
4. Restore the graph window on the desktop, then find autoscale X and Yaxis autoscale not work properly
If I didn't do step2. then autoscale work fine. I attached the bitmap for explain the problem.
Thank you.
(3,262 Views)
I was not able to reproduce this behavior.  Please attach a small example exhibiting the behavior.
In the meantime, in the Resize event of the form you could try rescaling the graph.
Andy McRorie
NI R&D
(3,242 Views)
