XYCursor and multiple X-axis
In my application I have WaveformGraph containing one WaveformPlot, two X-axis and one XYCursor. The cursor
label X shows values from X-axis number one by default, but I want to use values from the second X-axis. Is there
a way to do this?
(3,444 Views)
The XYCursor has a property 'Plot', and this the only property you can use to connect the Cursor with 'Real World':
    XyCursor1.Plot = WaveformPlot1
The
WaveformPlot has a property XAxis. You can switch between x-axes by assigning
    WaveformPlot1.XAxis = XAxis1
or
    WaveformPlot1.XAxis = XAxis2
After you reassigned the XAxis property for your WaveformPlot, your XYCursor will automatically use the XAxis you assigned.
(3,434 Views)
