Nianlys.dll dependancy
I've created a .NET application using MS2015 Filters library.
On Windows 7, I've 'just' to install some dependancies : CVI_Analysis.msi, mlk.msi and MStudioAnalysisRuntime.v450.msi
to run my soft and use Nianlys.dll library dll
But now on windows 10. Even after the installation of the dependancies, the nianlys.dll is nowhere to be found. So, of course, my soft crash.
Is somewhere can help me.
Thanks.
Florent.
Message 1 of 13
(3,282 Views)
Someone from the community hsa already encountered this problem, which is described here.
The problem might be in the incompatibily of the software and OS's bitness.
Message 2 of 13
(3,239 Views)
Hi.
Thanks for the answers.
Problem is.
As our computers are not admin authorized, We don't/can't use setup file to install our software.
We pass the computers once on the admin desk to install the depandancies.
After the users have just to install the soft via a zip file.
The dependancy used to install nianlys.dll doesn't work on windows 10.
Message 3 of 13
(3,221 Views)
Did you try to go to Build -> Configuration Manager and change the Platform entries of the Projects to x86?
Message 4 of 13
(3,219 Views)
Hi.
Yes, it is in x86.
The problem comes from the dependancy "MStudioAnalysisRuntime.v450.msi and CVI_Analysis.msi which don't install the dll (nianlys.dll) in the NI program files directory.
I don't know why 😞
Message 5 of 13
(3,210 Views)
Did you try to repair Measurment Studio from the Programs and Features of Control Panel?
Message 6 of 13
(3,203 Views)
Yes, several times. :((((
When I install the dependancies via the setup, it's ok. no problem.
Message 7 of 13
(3,186 Views)
If all of those steps did not help, I would recommend to contact your system administrator to reinstall the package.
Thank you and have a good day!
Message 8 of 13
(3,180 Views)
Hello.
Done, nothing new :(.
Message 9 of 13
(3,172 Views)
Is there a way to manually install the nianlys.dll ?
Thanks.
Message 10 of 13
(3,159 Views)
