ObjectDisposedException with ChartCollection an WPF Graph
When I'm starting the following program (WPF .net4.0, NI.common (13.0.40.190), NI.Controls.Graph (13.0.40.242) ) I'm getting the following error message from the debugger
ObjectDisposedException was unhandled
The data store was modified.
Object name: 'Buffer<Int32>'.
Source: NI.Common
I have a device class that generates every few milli seconds some random data. I notify my main class via Events and pass the values via paramter.
In XAML I bind the graph data to a ChartCollection as follows: (the bold lines are most relevant)
The error occurs only when the timing of my data provider gets over a certain treshold.
500ms - all is fine
200ms - runs ok, but crashes with exception when I change  the window size
20ms - still ok
10ms - crashes instantly with the exception
        Data data = new Data();
        public event PropertyChangedEventHandler PropertyChanged;
        protected virtual void OnPropertyChanged(string propertyName)
            var handler = PropertyChanged;
            if (handler != null) handler(this, new PropertyChangedEventArgs(propertyName));
        private ChartCollection<double> _chartCollection1 = new ChartCollection<double>(1000);
        private ChartCollection<double> _chartCollection2 = new ChartCollection<double>(1000);
        private ChartCollection<double> _chartCollection3 = new ChartCollection<double>(1000);
        private ChartCollection<double> _chartCollection4 = new ChartCollection<double>(1000);
        public ChartCollection<double> Graph1
            get { return _chartCollection1; }
            set
                if (_chartCollection1.Equals(value))
                    return;
                _chartCollection1 = value;
                OnPropertyChanged("Graph1");
        public ChartCollection<double> Graph2
            get { return _chartCollection2; }
            set
                if (_chartCollection2.Equals(value))
                    return;
                _chartCollection2 = value;
                OnPropertyChanged("Graph2");
        public ChartCollection<double> Graph3
            get { return _chartCollection3; }
            set
                if (_chartCollection3.Equals(value))
                    return;
                _chartCollection3 = value;
                OnPropertyChanged("Graph3");
        public ChartCollection<double> Graph4
            get { return _chartCollection4; }
            set
                if (_chartCollection4.Equals(value))
                    return;
                _chartCollection4 = value;
                OnPropertyChanged("Graph4");
        public MainWindow()
            InitializeComponent();
            GraphView graphView = new GraphView();
            ContentControlGraph.Content = graphView;
            ContentControlGraph.DataContext = this;
            data.dataReadyEvent += dataEventHandler;
            Closing += MainWindow_Closing;
        void MainWindow_Closing(object sender, CancelEventArgs e)
            data.Stop();
            Environment.Exit(0);
        private void ButtonBase_OnClick(object sender, RoutedEventArgs e)
                data.Start();
        private int j;
        private void dataEventHandler(object sender, EventArgs e)
            j++;
            if (j == 1)
                Graph1.Append((double[])sender);
            else if (j == 2)
                Graph2.Append((double[])sender);
            else if (j == 3)
                Graph3.Append((double[])sender);
            else
                Graph4.Append((double[])sender);
                j = 0;
The exception occurs in the DLL, so I cant catch it either.
(4,930 Views)
Accepted by Treckl
I believe you are running into the multi-threading issue described here: Can't get Graph.DataSource to work in WPF i (threading issue?).
In short, your chart append calls should be marshaled to the UI thread.
~ Paul H
(4,921 Views)
