Problems Transferring Setup from PC to Rigol DS2072A DSO using MessageBasedSession.
I'm using c# .net to communicate with the DSO using MessageBasedSession. So far have been able to upload Event Tables from the DSO to pc ok.
Below shows the System Setup Command: SystemSetup.jpg
  I can save the DSO Configuration data to the PC:
Code: [Select]
 string loadCommand = ":SYSTem:SETup?";
                mbSession.Write(loadCommand);
                mbSession.ReadToFile("D:\\DSOSetupRTF.stp"); /
but not back again to the DSO - nothing happens:
Code: [Select]
  loadCommand = ":SYSTem:SETup ";
                     mbSession.WriteFromFile("D:\\DSOSetupRTF.stp");
I wonder if MessageBasedSession is correct for this purpose? The only other reference I've found on this is the following post  (here😞
They are, I think, using Linux (or some such) - but I would also think that .Net should have a corresponding function. So I guess my question is what can I use in .NET to get this working, as it seems to do in the above post?
Message 1 of 1
(2,862 Views)
