WPF Legend: context menu
Is there any way with the WPF Legend control to detect the type of item the user clicks on when they right click to open a context menu? I have an application showing plots and cursors in the legend. When the user clicks on a cursor, I want to serve up a context menu for that cursor. If they click on a plot, I want to present a context menu for that plot. Not only do I need to know the type of item, but also which item specifically they click on.
I do exactly this in WinForms with the legend control there. There does not appear to be a similar mechanism in WPF. Am I missing something?
(3,912 Views)
Hi dpstark,
What version of Measurement Studio are you using? When doing this with WinForms are you using a reference to the item type?
ShaneK
Applications Engineering
(3,881 Views)
Measurement Studio 2015 for VS 2013.
In WinForms, I use
legend.GetItemAt(e.X, e.Y)
where e is the MouseEventArgs from a MouseDown event to retrieve the LegendItem at that point (or null). If it's a cursor, I display a cursor menu. If it's a plot, the plot menu, etc.
I can't find a similar method for WPF Legend because it only returns that a label, button, etc., was clicked- not a LegendItem.
(3,878 Views)
The legend does not expose any programmatic way to access the items it displays. However, like an ItemsControl, the legend supports customization through data templates. For example, to show a right-click ContextMenu, you could declare a data template resource like that shown below:
    <ni:Legend.Resources>
        <DataTemplate DataType="{x:Type ni:​Plot}">
            <StackPanel Orientation="Horizontal" Background="Transparent">
                <StackPanel.ContextMenu>
                    <ContextMenu>
                        <MenuItem Header="Plot Menu" />
                    </ContextMenu>
                </StackPanel.ContextMenu>
                <niPrimitives:LegendGlyph Renderer="{Binding ActualRenderer}"
                                          Background="{Binding ItemBackground, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}"
                                          Width="{Binding GlyphSize.Width, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}"
                                          Height="{Binding GlyphSize.Height, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}" />
                <ContentPresenter Margin="3"
                                  VerticalAlignment="Center"
                                  Content="{Binding Label}"
                                  ContentTemplate="{Binding LabelTemplate}" />
            </StackPanel>
        </DataTemplate>
    </ni:Legend.Resources>
~ Paul H
(3,874 Views)
