Programmatically change Graph axis range C#
I got mine to work but  just wanted to make sure I am doing it properly.  I'm only asking because I had to use casting and hardcoded element retrieval.
This is what works for me:
AxisDouble Yaxis = (AxisDouble)Graph.Axes.ElementAt(0);
Yaxis.Range = new Range<double>(-25000, 25000);
I also set Adjuster="None" in XAML.
Thank you.
(5,481 Views)
Accepted by kirko7
Your approach is fine. Since you are declaring the axis in XAML, you could also use a name instead of referring to it by index location:
    <ni:AxisDouble x:Name="Yaxis" Adjuster="None" ... />
~ Paul H
(5,476 Views)
Much better.  Didn't think of that...
Thank you
(5,473 Views)
