Referencing National Instrument DLL's crashes Visual Studio 2008
I am referencing my application to NationalInstruments.Common.dll (8.9.35.302) and NationalInstruments.DAQmx.dll (9.1.35.15).
My problem: if the main window of my application ist open in the Visual Studio IDE and I then start debugging (means: run my application) then the Visual Studio crashes.
If I remove the references to the NationalInstruments DLL the Visual Studio never crashes.
Does anybody have similar experiences and any possible reason/solution to this?
Message 1 of 10
(5,626 Views)
HI Daniel,
normallly a crash happens, when the call is wrong - means wrong parameters, so that wrong memory is allocated.
Can you post the code?
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 2 of 10
(5,617 Views)
There is no code yet. I have removed all code that is accessing NI-DAQ from my project. I am only referencing the DLLs (.NET components) in my project settings. (Visual Studio 2008 --> Solution Explorer --> References).
Message 3 of 10
(5,613 Views)
Can you please post your whole project?
Thanks!
Ramona Lombardo
Message 4 of 10
(5,610 Views)
Hello -
Just curious, do you have Visual Studio 2010 installed on this machine where Visual Studio 2008 is crashing??
NickB
Message 5 of 10
(5,598 Views)
Interesting question 🙂
I had Visual Studio 2010 installed but removed it again later. But really my problems started, after Visual Studio 2010 has been installed!
I am currently setting up a "clean" new PC to find out if the error will also occur there....
Message 6 of 10
(5,596 Views)
We do know of an issue with installing Visual Studio 2010 alongside National Instruments driver software.  However, because of the nature of the fix, I would like to contact you offline regarding a fix for this issue.  Do I have your permission to contact the forum administrator and get your email address?
Thanks -
NickB
Message 7 of 10
(5,593 Views)
I would be very happy if you contact me by email. Please feel free to get my address from the administrator.
Message 8 of 10
(5,591 Views)
Thanks - I will be contacting you as soon as the forum administrator gets back to me.
Also - just FYI and for anyone else who may run into this in the future, there is a KB for this issue.  However, because of the current nature of the fix for this issue, it simply asks you to contact NI support.  The KB will be updated as a more sustainable fix becomes available.
Thanks again - and sorry for any inconvenience,
NickB
Message 9 of 10
(5,587 Views)
I am having a related problem to this. I am trying to use DAQmx 9.1.35.15 in a .net 4.0 WPF application using VS2010. The application compiles fine and VS2010 does not crash, but when I run the application in debug mode I get the following error: Could not load file or assembly 'NationalInstruments.DAQmx.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A).
Is it possible that this related to the issue in this thread?
I do not have VS2008 installed.
Steven
Message 10 of 10
(5,422 Views)
