reading a digital input from inside an analog callback
hi folks, I am working on a usb 6008 daq board with visual studio 2003 and measurement studio 7.1. I have an analog task working fine, now I need to read also a digital input to check if the user is pushing a button. I have created a digital task with a single channel and a single sample reading on demand, and I have put inside the analog callback the
Led1.Value = myDigitalReader.ReadSingleSampleSingleLine
code, so that when I change the input value, a led goes on and off.
the code compiles fine, but unfortunately when i run the program, at this line the program stops working without sending error messages. I have tried debugging but the cursor disappears. Any ideas?
it would be even better if there was a way to detect when the digital input changes its state without reading the input at each iteration.
tks
nunzio
(3,460 Views)
Hi nunzio,
you can try to modify your code as follow
Led1.Value = myDigitalReader.ReadSingleSampleSingleLine()
Otherwise you can read this or this post to try to find a different solution.
Please tell me if you resolve your issue.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(3,442 Views)
Tks a lot Simone for your reply. It was my stupid fault, I hadn't correctly initialised the digital task. Now it works perfectly.
NI rules!
ciao
n.
(3,403 Views)
