Im using a PCIe 6351 DAQ. I would like to aquire a finite number of samples with the analog channel that starts with a trigger singal coming from another analog port  (APFI0) and repeat the process each time the triggers. To be more precise I have a square signal for the trigger and I would to acquire N samples at each rising edge. I have selected the starttrigger as retriggerable but in all the examples that I can find when the trigger start and the acquisition takes place, the information is recovered with the EndReadMultiSample() and you must restar the acquisition with BeginReadMultiSample which makes me lose triggers in the meanwhile. Any idea or example on how to solve this?
Thank you very much.
