Running Multi-Counters with NI9361
I have a cDAQ-9181 and 9361,To measure two angle encoder at the same time, How can I run two Task at the same time with C# , And Read the Angle respectively.
Thanks.
(2,327 Views)
Accepted by Shawn_pmc
In the official documentation is an example to run a task on a different thread asynchronously you can use this with a few changes. I created my Tasks at first in the main programm. Then you can use the example and change it so that it doesnt create the task but takes a given one in the constructor. This way i could get multiple tasks running at the same time. If you update UI elements just watch out for thread save calls.
public class DaqThread : IDisposable
        private ManualResetEvent runningTaskWaitHandle; // Used for synchronization while disposing task
        private NationalInstruments.DAQmx.Task runningTask;
        private NationalInstruments.DAQmx.Task continuousTask;
        private AnalogMultiChannelReader analogReader;
        private AsyncCallback analogCallback;
        private AnalogWaveform<double>[] data;
        private Pruefung parentWindow;
        public DaqThread(NationalInstruments.DAQmx.Task taskToRun, Pruefung parentWindow)
            runningTaskWaitHandle = new ManualResetEvent(true); // Instantiate wait handle
            continuousTask = taskToRun;
            this.parentWindow = parentWindow;
        #region IDisposable Members
        // Dispose method executes on the main thread
        public void Dispose()
            SafelyDisposeTask();
        #endregion
        // StartAcquisition method executes on the main thread
        public void StartAcquisition()
            try
                analogReader = new AnalogMultiChannelReader(continuousTask.Stream);
                analogReader.SynchronizeCallbacks = false;
                analogCallback = new AsyncCallback(AnalogReadCallback);
                // Create a reference (runningTask) to the task running (continuousTask)
                runningTask = continuousTask;
                analogReader.BeginReadWaveform(Convert.ToInt32(continuousTask.Timing.SamplesPerChannel), analogCallback, continuousTask);
                Debug.WriteLine("Schreibe: " + continuousTask.Timing.SamplesPerChannel.ToString());
            catch (DaqException ex)
                // Exception thrown
                runningTask = null;
                continuousTask.Dispose();
        // StopAcquisition method executes on the main thread
        public void StopAcquisition()
        // AnalogReadCallback method executes on
        //   - worker thread when SynchronizeCallback is set to false (current behavior)
        //   - main thread when SynchronizeCallback is set to true
        private void AnalogReadCallback(IAsyncResult ar)
            try
                // Check to see whether the task is still running
                if (runningTask != null && runningTask == ar.AsyncState)
                    data = analogReader.EndReadWaveform(ar);
                    // If ProcessData is updating UI components created on the main thread, then
                    // invoke ProcessData on the main thread when SynchronizeCallback is
                    // set to false.
                    ProcessData();
                else
                    // Signal waiting thread to proceed
                    SignalThread();
                // Exception thrown
                runningTask = null;
                SignalThread();
        // ProcessData method executes on same thread on which AnalogReadCallback executes
        private void ProcessData()
            // If this method is updating UI components created on the main thread, then invoke
            // the UI code or this entire method on the main thread when SynchronizeCallback
            // is set to false.
        // SafelyDisposeTask method executes on the main thread
        private void SafelyDisposeTask()
            if (runningTask != null)
                if (!analogReader.SynchronizeCallbacks)
                    // When SynchronizeCallback is false, the callback will be executed on
                    // the worker thread. In that case, wait for the pending callback to be
                    // completed before disposing task.
                    // Reset wait handle to wait for callback, which is on the worker thread
                    runningTaskWaitHandle.Reset();
                    // Set runningTask to null to indicate the callback, not to initiate
                    // additional reads
                    runningTask = null;
                    // Wait for pending callback on the worker thread.
                    //   - If the last operation on runningTaskWaitHandle is Set (in SignalThread),
                    //     WaitOne will not wait and proceed to execute the next line of code.
                    //   - If the last operation on runningTaskWaitHandle is Reset (in
                    //     SafelyDisposeTask), WaitOne will make the main thread wait for the signal
                    //     (Set Operation on runningTaskWaitHandle)
                    runningTaskWaitHandle.WaitOne();
                else
                    // When SynchronizeCallback is true, this method and the callback will
                    // be executed on the main thread. In that case, there is no need to wait for pending
                    // callback to be completed before disposing task, because the callack
                    // and this method cannot execute at the same time.
                    // additional reads
                    runningTask = null;
            // Safe to dispose task
            if (continuousTask != null)
        // SignalThread method executes on the worker thread
        private void SignalThread()
            // When SynchronizeCallback is false, the callback will be executed on the worker
            // thread. In that case, while disposing task, the main thread is waiting on the callback
            // which is executing on the worker thread to be completed. Signal (call Set
            // operation on runningTaskWaitHandle) the main thread to proceed
                runningTaskWaitHandle.Set();
This example is for reading analog data but I think you could also use this. Another way could be just to use one Task for different devices if you are reading data with the same clock.
Greetings
Marius
(2,258 Views)
Hi  Marius,
Thanks for your reply. I already found a Method (CounterMultiChannelReader) in the DAQmx Library. Which can Read two channel's Values in one Task. And It's works.
public ConnectingForm()
InitializeComponent();
asyncCB = new AsyncCallback(CounterInCallback);
private void RunTask()
Task = new NationalInstruments.DAQmx.Task();
Task.CIChannels.CreateAngularEncoderChannel (Channel1 , "", CIEncoderDecodingType.X4, false, 0, CIEncoderZIndexPhase.AHighBHigh, DataHost.PulsePerRevolution, 0.0, CIAngularEncoderUnits.Degrees);
Task.CIChannels.CreateAngularEncoderChannel (Channel2 , "", CIEncoderDecodingType.X4, false, 0, CIEncoderZIndexPhase.AHighBHigh, DataHost.PulsePerRevolution, 0.0, CIAngularEncoderUnits.Degrees);
Task.Timing.ConfigureSampleClock("", SampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, 1);
runningTask = Task;
counterInReader = new CounterMultiChannelReader(Task.Stream);
counterInReader.SynchronizeCallbacks = true;
Double data = new double[NumberOfSamples, NumberOfSamples];
counterInReader.BeginReadMultiSampleDouble(NumberOfSamples, asyncCB, Task);
Still appreciate your reply. And provide a example to help others.
(2,237 Views)
