SerialSession
Sometimes when opening a SerialSession I get a NationalInstruments.VisaNS.VisaException: Specified type of lock cannot be obtained, or specified operation cannot be performed, because the resource is locked.  VISA error code 0xBFFF000F, ErrorResourceLocked.
Usually this occurs while debugging, e.g. after killing the process that owns this dll and restarting it.  The strange thing is that both in hyperterminal and the measurement and automation explorer, I can open the port and communicate without problem.  Restarting the computer will fix the problem but that is a little drastic.
Any ideas?
Jeff
Message 1 of 13
(6,885 Views)
Hey Jeff,
That error code usually means that the resource you're trying to access has been locked by another process. In this case, you probably didn't use a VISA close to close the previous VISA session. If that's the case, then you don't need to reopen that session. You should just be able to do reads and writes to the current session. If you want to reopen the session, then just make sure to end the process by using a VISA close when you're done with it elsewhere in the code.
Hope this helps!
Jason W
Application Engineer
Message 2 of 13
(6,852 Views)
Hello Jason,
I figured something like that; normally I will close the session but when things crash or processes are killed I don't have the opportunity.  Before I didn't see how I could get the session pointer without creating a new one but I'll look at the NI API more thoroughly now.
Jeff
Message 3 of 13
(6,844 Views)
No luck in figuring out how to get the SerialSession pointer without calling new (which gives the exception).  Any idea on how to do this?
Jeff
Message 4 of 13
(6,825 Views)
Hey Jeff,
If I understand what you are asking correctly, I believe this knowledge base will answer your question.  Make sure you take a look at the attached pictures.
Hope this helps!
Jason W
Message 5 of 13
(6,819 Views)
Hello Jason,
Sorry I didn't see any relevant information in the knowledge base article because
1) I can't close the session programmatically if the module crashes.
2) Unlike the article the port really isn't in use since I can, subsequent to the exception, open it in Hyperterminal or NI's Explorer.
3) Maybe what the picture shows is some way to enumerate all the in-use Visa port sessions.  If so I need to know what API to call to do this in C# (preferably) or C/C++.
Another way to phrase the question is how and why NI's explorer can open the port and my C# code can't?  Maybe this is due to a limitation in Visa's C# implementation and I need to call some Visa C API?
This is very important for my project because the alternative of restarting the OS will reset all the USB devices which is highly undesirable.
Jeff
Message 6 of 13
(6,815 Views)
Hey Jeff,
What version of VISA are you using?
Jason W
Message 7 of 13
(6,774 Views)
Hello Jason,
The VisaNS dll is version 8.0.20.177
NI-Visa 3.6
visa32.dll 3.6.0.49153
nivisaserver.exe 3.6.0.49152
nivisaic.exe 3.6.0.49152
HTH,
Jeff
Message 8 of 13
(6,767 Views)
Hey Jeff,
Something I would recommend is updating your VISA driver from 3.6 to 4.0. You can download the latest driver here.
The new driver may have improved coding to deal with crashes in the middle of a program by a crash, or an abort.
Are you able to replicate this with a simple program? I opened an example program in labVIEW and did an abort in the middle of a serial write session, and then as long as I ran it again, and made sure to close the VISA session everything was fine. I know you're programming in C++, but the driver function calls should be the same. I am using VISA 4.0, so it may be as simple as a driver upgrade that will solve this problem.
Can you let me know if that helped?
Good luck!
Nick D.
Message 9 of 13
(6,730 Views)
Hello Nick,
I'll try updating to VISA version 4 this afternoon and see if it works.
One problem I have is how can I close the Visa session when rerunning my module as you are doing in LabVIEW?  Normally I need a pointer (actually reference) to the session in order to call the close function.  I suspect there must be some low level close function, probably in C, that I can call to close.
Another possibility is that this is a C# bug, and that the Visa session is really closed but some NI module has a variable that says it wasn't closed.  This would explain why I can still open the port using NI's Explorer or Hyperterminal.
Jeff
Message 10 of 13
(6,727 Views)
