What is the best way to access VisaExceptions in cases where they are not explicitly thrown?
ArgumentException thrown with VISA ErrorInterfaceNumberNotConfigured embeded.  I know this exception will be thrown on occassion and want to check for it and other possible excpetions.  I can write a regular expression to extract the VISA error code from the message but this seems a bit sloppy.  Casting the exception as a VISAException also does not work because the ArgumentException is missing details found in the VISAException class.
Peter
(3,198 Views)
Hello Peter,
Extracting the information that you want from the VISA error cluster is a great way to achieve what you are looking for.  You can then look specifically for that the exception you are interested in or all VISA errors.
Meghan
Applications Engineering
(3,179 Views)
