SetLine In DotNet
Hi Everybody,
I develop an application using VB.NET and VISION.
I want to do a SetLine to change some pixels of my Image. Unfortunately  i have the exception
"You have passed an invalid type into a parameter of a VARIANT type"
Here is an example of code:
Dim Image As New NationalInstruments.CWIMAQControls.CWIMAQImage
Dim line As New NationalInstruments.CWIMAQControls.CWIMAQImage
Dim data(,) As Byte
Dim ligne As New NationalInstruments.CWIMAQControls.CWIMAQLine
Image.Type = NationalInstruments.CWIMAQControls.CWIMAQImageTypes.cwimaqImageTypeU8
line.Type = NationalInstruments.CWIMAQControls.CWIMAQImageTypes.cwimaqImageTypeU8
line.SetSize(1, 100)
Image.SetSize(100, 100)
ReDim data(1, 100)
data = line.ImageToArray()
ligne.Initialize(1, 1, 1, 100)
AxCWIMAQVision1.SetPixel2(line, New NationalInstruments.CWIMAQControls.CWIMAQPoint, 1)  // Ok with this function
AxCWIMAQVision1.SetLine2(image, ligne, data) // Exception Thrown here
I understand well that AxCWimaqVision is an active X control and NI supplied a wrapper code of the C++ VISION DLL for DotNet. So we have to pass VARIANT type.
But in dotnet the Variant Type is the object type. In My code SetPixel accepts an integer and the DLL cast for the appropriate type to do the function...
In SetLine i have tried an array of byte , an object ... It doesn't work strange...
In LV and CVI there is no problem. In CVI we pass a char* to the data type
Thanks a lot!!
(4,595 Views)
Hi kikou,
You're using the ImagetoArray function, which creates a 2D array.  The array is just an array with one column, so it seems like a 1D array.  You will need to bring this down to a 1D array to use it in the SetLine2 function.
Stephen Meserve
(4,562 Views)
Accepted by kikou
Hi
You are right... I have a linescan camera delivering one line of 12288 pixels i didn't see that the image is still a 2D array
But the best way to do that is to use GetLine and then SetLine...
An other function is more optimized, is ImageToImage. With this function it is not necessary to convert image to arrays!!
(4,542 Views)
